Duncan8943
- Lexington
I've got a 100A combo meter base/disconnect box. This is to be used as a temporary service. The box has a neutral bar with a bonding screw and a seperate ground bar. Is there a difference between (1) Tying the ground wire to the ground bar and bonding the neutral bar to the panel or (2) Tying the ground wire to the neutral bar and bonding the neutral bar to the panel. Normally, I would tie the ground wire to the neutral and then use the bonding screw.
