- Tennessee NEC:2017
- Semi-Retired Electrician
Does it harm either the ballast or lamp to use just two lamps in a fixture that has a 4-lamp ballast, and is wired for four lamps?
If so, would you just leave off one red and one blue wire when wiring the ballast?
This is if you are using a ballast that can run up to 4 lamps.
Almost forgot, this would be a T8 electronic ballast.
