I have a 3KVA transformer that will step a 460V primary down to a 115-230V secondary. Does the NEC limit the number of fuses I can have on my secondary?
I have 2 actuators that will require 10Amps (@ 12VDC derived from a power supply on the secondary), a 230V motor that will draw 3A, and the remaining 115V control circuit which will draw around 5A.
How do I derive the maximum amps for fusing on a mulitple tap secondary? If I use 115V as my secondary I get 26A * 1.25 = 35A CC fuse. But, the entire load of the secondary is not on the 115V tap because I have the motor at 230V. Can I have a 9A fuse for the 115V control circuit, 15A fuse for the actuators, and a 5A fuse for my motor?
