Need Double gang metallic box for old work?
24flinchin
las vegas nv
Im needing to install quad receptacles into a drywall wall in a commercial buildings office. Ill be using MC so I need to use a metal box as well. I know they make double gang boxes for old work out of plastic but what do I use for a metallic box in an existing wall? Thanks
they also make those in metal;)
We usually use these gangable units and join as many as required.
However, Hubbell/Raco offers several solutions:
Raco Old Work Box Single Gang convertable to multi-gang #523 - 3" x 2" Switch Box, 2-1/2" Deep, Gangable, MC/BX Cable clamps, Old work clips.
http://www.hubbellcatalog.com/raco/RACO_datasheet.asp?PN=523&FAM=RacoBoxes
Raco Old Work Grip #969 - Accessory, Old Work Box Support, coverts any box with ears to old work box.
http://www.hubbellcatalog.com/raco/RACO_datasheet.asp?PN=969&FAM=RacoBoxes
Raco #970RAC - Accessory, Switch Box Support, for Old Work.
http://www.hubbellcatalog.com/raco/RACO_datasheet.asp?PN=970RAC&FAM=RacoBoxes
Raco #977 -- Accessory, Grip-Loc Old Work Switch Box straps/supports
http://www.hubbellcatalog.com/raco/RACO_datasheet.asp?PN=977&FAM=RacoBoxes
Raco Retro-Ring
http://www.hubbellcatalog.com/raco/RACO_datasheet.asp?PN=206RAC&FAM=RacoBoxes
Also available for NM
Raco Old Work Box Single Gang convertable to multi-gang #517 - 3" x 2" Switch Box, 2-1/2" Deep, Gangable, NM/SC Cable clamps, Old work clips.
http://www.hubbellcatalog.com/raco/RACO_datasheet.asp?PN=517&FAM=RacoBoxes
A question like that should be directed to your master, foreman or boss. If none of them know the answer, you could try the supply house. If they don't know, try google. If google doesn't know, ask here :roll:
Google may often take you here. If I recall that is how I first found this site was when I had a question on something and google took me here.
Thanks for all the ideas, I didnt realize there were so many options. I appreciate everyones time to help me. And yes, Google brought me here and I was happy to have found it.
