- Tennessee NEC:2017
- Semi-Retired Electrician
Do you think the outer sheath on 6-2 NM is any stronger/thicker than say, 12-2 NM?
I was just thinking about that and wondered if the larger size NM would keep out moisture better than the smaller 14-2 or 12-2.
I saw some 6-2 inside a conduit the other day. It was under a deck that also had a covered roof. I was just wondering if the 6-2 NM would hold up to whatever moisture would/could get in the conduit.
