island Greg
New member
- Little Corn Island, Nicaragua
I would first like to say that I have browsed several older post on this subject here. But the subjects were much more involved then my simple question. Sorry in advance if my question has been discussed before. I just have not found anything to help answer / solve my problem.
I recently moved to a remote island off of Nicaragua. A restaurant asked me to install a 20amp receptacle. While doing this install I noticed that the neutral to ground (earth) gave me a reading of 56Vac. Hot to ground (earth) read 68Vac. This giving me 124Vac across hot to neutral. Everything seems to work fine in the restaurant, running fridges, freezers, fans, blenders and so-forth.
The ground (earth) is not connected to the neutral in any form. The ground is connected to the earth via a 8ft copper grounding rod.
Should neutral be connected to the ground? Or do I have another problem and this would create a short since the neutral's voltage is so high (56Vac).
Thank you for your time and response.
