jwelectric
- North Carolina
I suppose that in order to ?connect? to it something must be installed to connect to.I know this is maybe being nit picky, but some of the details involved here come down to interpretation of certain key words so, do you install a portable generator or do you just connect to it?
That is odd because most portable generators that I have seen have the neutral "floating" which implies installation as a non-SDS. ~confused~
I thought the discussion was the installation instructions that are included in the listing and labeling of equipment. If the generator is listed with the receptacle mounted on the frame then it will not have a floating neutral.Same here.
