Elektrotechnik
- USA
Hello,
I'm trying to verify that my math is correct for a reliability test that I'm designing. I'm using 2W load resistors that are powered by 14 Volts. Am I correct in needing these 2W load resistors to be rated at 10 miliOhm? Each resistor would be receiving 143 mA, and I used that to determine the 10 miliOhm resistance.
I have 9 of these load resistors. In the test, they are powered by a voltage-driven power source of 14 V. They are connected in parallel with the 14 V and the ground.
How much current do I need to supply from the power supply?
