chevyx92
- VA BCH, VA
Is it allowed by code (2008 NEC) to install UF cable underground from house to a 4x4 post and mount GFCI outlet with in-use cover to run pool pump? I don't believe it's required that the EGC be insulated, right? Also I know the outlet cant be less than 6ft from the inside wall of pool. But could the outlet be less than the 6ft if it was under a deck that what built around the pool?
