Does anyone know the minimum IP rating for enclosures in order to obtain a CE marking? I know motors must at lest be IP23, but I am not sure about the rest of the industrial machine enclosure that has air vents and other openings.
As a practical matter, I think the answer is IP21.
You are correct. CE marking is self declared.
Can be using the technical construction file route.
Still not able to find a definitive answer on the butt-splices. I believe that as long as any splicing is crimped and not a screw terminal it will be fine. Please let me know if anyone knows anything to the contrary. Thanks.
For an IP2X rating I have found a test that states the opening must be less than 12mm wide. Or it can be more than 12mm but less than 25mm wide, as long as there are no hazardous locations within 18mm of the opening. Does anyone know what the distance to a hazardous location has to be if the opening is more than 25mm wide? I have an opening at the bottom of my machine that is about 80mm wide. A person could theoretically lay on the floor and stick there arm inside of the gap and touch a very hot surface. Any suggestions on how to approach evaluating this?
Fit a mesh.For an IP2X rating I have found a test that states the opening must be less than 12mm wide. Or it can be more than 12mm but less than 25mm wide, as long as there are no hazardous locations within 18mm of the opening. Does anyone know what the distance to a hazardous location has to be if the opening is more than 25mm wide? I have an opening at the bottom of my machine that is about 80mm wide. A person could theoretically lay on the floor and stick there arm inside of the gap and touch a very hot surface. Any suggestions on how to approach evaluating this?
Among other things, use of either a butt splice or a wire nut will allow a wire to change color and size between one termination point and the next.We don't use them - most of our customer specifications do not permit their use. They like to be able to see all the conductor terminations and joints and such a connector could be hidden in trunking.
On the wire nuts - I don't know. We don't use them.
