- Chapel Hill, NC
- Retired Electrical Contractor
Suppose you have a 24 volt resistant element and put 24V DC to it? Would it make a difference if the trany was 120V-24 DC rather than AC
Thanks all. I thought that the case but wasn't sure-- Not sure why that thought popped into my head either.
Cheap liquor will have that effect on you.:lol:Thanks all. I thought that the case but wasn't sure-- Not sure why that thought popped into my head either.
[/B]
Aw c'mon Dennis fess up: What did you mis-hook up that did not smoke and burn up?![]()
Well. That's your problem right there.Ceb- Believe it or not you can fit all the alcohol I every drank and it wouldn't fill up an 8 oz glass.
Believe it or not you can fit all the alcohol I every drank and it wouldn't fill up a 8 oz glass.
All the alcohol I ever drank? Well, I saw a commercial once that suggested that I drink Canada dry. It's been a long haul! :happyyes:
It really isn't. It's that value instantaneously twice per cycle if you take the absolute value for both negative ad positive half cycles.Don't forget our 24 volt AC measured with our meter is really 33.95 volts.
This popped in my head. The heated mirrors on my trucks and car are on timers. They will run for about 3-5 min. and then shut off.Actual I did hook up a 24V defogger shower mirror but the customer says it gets very hot. I thought about changing the voltage to 12V instead of 24V so it did not get too hot. You would think there would be a thermostat built in but there does not seem to be.
The effective value or RMS for 24Vac is the same as 24Vdc.
But not every component/circuit can work with either.
A resistive heater would.
After getting by the drinking humor. This popped in my head. The heated mirrors on my trucks and car are on timers. They will run for about 3-5 min. and then shut off.
