Joseph Alexander
how long can the tap from a 50 amp range circuit be for a 20amp circuit for a microwave? I know this has to have been discussed before but I can't find it.
I think that's a wall mounted oven in the handbook exhibit, not a microwave. 210.19(A)(3) Exception 1 applies to tap conductors used to connect electric cooking equipment such as ranges or ovens (I don't think microwaves qualify).how about 210.19 it specifically shows this in the handbook ex 210.21
I appreciate your input, but I have yet to hear why you can tap a cooking device but not a microwave, especially since the word microwave does not even appear in the NEC.
What this discussion shows is that there needs to be a clear codification on the Microwave issue! I fail to see why after being in use for 50+ years that the code council will not address the microwave issue. All of this could be cleared up if the council would just put in writing:
A mounted microwave unit must be on a dedicated circuit.
FPN: The addition of this article does not mean that microwaves placed before this codification are exempt for this rule.
The reason I am asking about this issue is I am work towards my R-5 combination inspectors card. If I found this on an inspection I could not point to any code which prohibits this. At best the views we have discussed are our opinions. If you had to argue this point are you sure you are wright? I'm not and I have been doing this for 30+ years.
You can not connect the 5-15 or 5-20 receptacle directly to a 50 amp circuit.
You possibly could use a feeder tap and proper overcurrent protection to supply this receptacle.
Someone may find a place that prohibits this though.
It definitely would be more complicated if an older (then permitted) circuit that utilized the grounded conductor for grounding the frame of the range.
I don't believe the NEC recognizes a microwave in same "cooking appliances" category as they do ranges, ovens, and cooktops.[/QUOTE]
They don't. That's why they don't conceder a microwave in a motel room or a dorm room to be a kitchen even if it also has a refrigerator. Looks like a kitchen, smells like a kitchen but it's not a kitchen.![]()
What this discussion shows is that there needs to be acodification on the Microwave issue! I fail to see why after being in use for 50+ years that the code council will not address the microwave issue. All of this could be cleared up if the council would just put in writing:
While I agree with responses regarding run-o'-the-mill, cord-and-plug-connected microwave ovens, I do believe the discussion topic regarding built-in microwave ovens is worthy of debate...
http://www.google.com/search?source...F51mpA.O&fp=4a7c743a55275708&biw=999&bih=1151
...and there are microwave ovens that have an integral resistance-type heating element (browning, roasting, convection, whatever they decided to call it), if the question of heating-element type comes into play.
So let's focus on this type rather than the typical countertop nuke...
As long as microwaves have a 15 or 20 amp cord cap you are limited to 20 amps max overcurrent protection. You are correct - 210.21 is probably the biggest issue for the OP, and what he wishes to do.Still cord and plug connected are they not?
That would still rule out using 210.19 because of 210.21.
That said it just seems to me that 210.19 was written before microwaves and at this point should be reworked a bit to clear things up.![]()
I really doubt any proposal to change it so a cooking appliance with a 15 amp cord cap can be plugged into a 40 or 50 amp circuit will ever be accepted.
Pretty much true if they are just microwave ovens. But there are crossovers using multiple cooking technologies not always plug connected... but I will note they are not necessarily called microwave ovens. They are typically called wall ovens even though they utilize microwave cooking technology.Still cord and plug connected are they not?
As I so noted in my earlier post, let's focus on ones that are hardwired, not 15/20A plug connected... to give a proper reply to the OP.
Well, if that be the case, you are done posting on the matter.You are loosing me, as far as I could tell the OP is talking about a run of the mill microwave so I don't see how focusing on another type is going to give proper reply. :?
