I come up with 3.25 volts dropped over 75 feet of 14 AWG with a load of 6.9 amps.
You have to remember you will only draw 6.9 amps if the motor is fully loaded and is being supplied with 230 volts after any voltage drop is factored in.
Load on the motor is going to depend on how many GPM it is moving and how much vertical lift is necessary.
Raise the input voltage or change the actual load on the motor and things all change.
3.25 volts drop on 230 is only 1.4% drop. You do need to consider how much conductor and what size there is from the top of well to the pump also. and there is a good chance your actual input voltage is higher than 230, though we often don't consider this, the reality is many times the applied voltage is closer to 240 and the motor rated voltage is 230.
If this is a three wire instead of a two wire pump motor then current is split and voltage drop is not the same either. You will have full current on the common wire but it will split (not necessarily equally) across the two windings and the other two conductors.
