Cable/tie straps ok for pvc?
Unless you have some constraints from specifications on a construction project. Some inspector might find a reason you can't do it. I guess if you are running conduit in a barn out in the country nobody will ever know.
We use SS cable ties for outdoor applications - traffic signal cable on span wire. A SS cable tie, would be as good or better than a plastic two hole strap
