Hello all,
Curious , has anyone installed a residential whole house generator with solar system already installed. I believe there is a way to do this im just not sure how. I don't have much experience with solar. Any help would be greatly appreciated...
This would probably be better addressed in the Photovoltaic Forum, but a PV inverter should be interconnected outside the generator transfer switch. This will result in the PV system shutting down in the event of a power outage, which is better than having the PV system think the grid is still up when the house is on the generator. The reason for this is that if the PV system and the generator are both operating on the AC bus and the demand from the household loads drops below the output of the PV, the PV will backfeed the generator, which is very bad news for most generators.
This, of course, can be problematic if the interconnection point is a backfed breaker in the main panel of the house and the owner wants a whole house generator backup. The logical place for the transfer switch is between the meter and the panel, but this connects the generator to the PV inverter outputs.
I realize that some owners are doing this sort of thing expressly because they want their PV to keep producing during power outages, but it's not a great idea. The contribution to their bottom line by their PV system while the grid is down is usually minuscule compared to the damage the PV can do to the generator.
