olly
- Berthoud, Colorado
- Master Electrician
110.26 A1 gives you the distances in front of the equipment correct? Then 110.26 A2 is the distance left or right of the equipment correct? My question is about side clearances... From how i interpret 110.26 A2 is that you could stick a meter socket (for example) in a corner as long as you have 30" or width of meter socket if larger. And that the door could open 90 degrees. Or stick it right next to a fence ect. you just need clearance on that one side correct?
