If you took off all the devices, use a meggar on some wires.
Some wires in the circuit are existing. Some are new.
I don't have a megger, but if I did or can get one, If the wires are fine, Would not the inductive kick back cause the breaker to trip any way?
If there is a damaged wire, would not, should not it trip with no loads or the A lamp installed?
gar.. sounds good, but I don't think they want additional lights coming on with the in the pool pool lights. Especially, A light in the panel... :- )
Thank you for the calculator links eHunter.... why did you pick 2.7k ??? just wondering.
And I can see the calculations.......but how or why did in the calculation of 5 w's jump to 25 w for the suggested resistor?
Rich
