Sparky Adam
Master Electrician
- Dallas, TX
- Operations Manager / Master Electrician
Hello,
I am working on a high rise residential building that is fed with 480v. When I went in to disconnect the water pumps I tested the lugs that fed the breakers for the pumps in their control enclosure and found that from phase to phase I had 480 volts, but when I tested from the can to each of the phases my tester read 120 volts. What kind of system is this? I am not familiar with anything like this.
Thanks!
Thanks!
