KarlS
- Houston, TX
I have a spec that requires XHHW-2 Tinned for all wire. The are insisting all gnds meet this requirement. The trouble is I cannot this this special wire in green. The NEC states all #6 and smaller must be green insulation. I am running #6 equipment gnds from the panelboards etc from the panel to the ground bar loop on the building wall. THese are equipment grounds from the panel to the ground bar. I can get this #6 black with a green stripe. I have not found where I can use this in the code and prefer green insulation. Any help would be apreciated.
I also have 4/0 black which I intend to phase tape from the major equipment and cable trays down to the busbar for equipment grounds. I prefer green for this application but cannot find in this type cable
