MRKN
- California, USA
Hi,
I need to design an equipment ground for a steel structure (used for operator access to some piping and valves at the top of a ~50' vessel) which will be installed in an existing process plant. Actually we'll be grounding this structure at two separate points.
I know the structural steel will not extend 10' into the ground (this discounts possible credit for the framework as a grounding electrode itself), but am curious on the typical ways such a structure is grounded when installed in an existing location. I would propose connecting (via an approved means) a 2/0 Cu stranded wire to some particularly convenient steel beam and running it via PVC conduit to an existing nearby ground well (with ground rod). This is cheaper than the alternatives, which I see as: to run the EGC 24" underground to an existing ground well, or to simply create two new ground wells with ground rods on diagonally opposite corners of the structure right at the foot of the beams.
I can't find anything wrong with this in the code since the PVC would mechanically shield the ground wire from any damage... thoughts?
