My boss has one of those and it is great. Need to keep a lot of spare blades around; they crack every once in a while.When I used to run a lot of 1/2 and 3/4 EMT we used the makita cordless sawzall. This tool was small compact weighed little. Could use in a holster and cut very fast equal to the bandsaw. Worked great with one hand. Try that with bandsaw
A Sawzall is not your best choice for repetitive cuts on conduit. The best tool is a bandsaw. I use the Milwaukee M12 cordless band saw and love it. Some of my co-workers use a metal cutting blade in a cordless 5 1/4" circ saw, but they are noisy and throw a lot of metal chips. Get a bandsaw and you wont regret it.
I have been having a lot of trouble cutting pipe with the Sawzall. Even the small stuff. Just started a job doing commercial work, and we have 1/2 and 3/4 emt to cut. We're told to use the Sawzall with 1 hand, pipe in other. No mounts or anything are really available.
I am not sure what I am doing wrong, maybe its a strength issue. The pipe vibrates, the saw moves, I really don't get any progress. I get very annoyed and just use my hacksaw to get through it. It is a bit slower, but it gets the job done.
I want to get better at my job, and am willing to invest in to tools. I would like to be able to cut pipe a lot faster. Any tips on what I could be doing wrong, or tools I could get that are faster than the hacksaw.
Works great for PVC too, and often can even be used on tubing that is in place. They also make very stubby ones that do not require as much room to swing. Pretty much guarantees a square end.Back when I did real work we used these.
http://www.globalindustrial.com/p/b...mpaignId=T9F&gclid=CJKpvNSDirkCFZBAMgodmwgAAQ
These posts always make me feel old. I just always used a hacksaw. Sometimes a tubing cutter.
I've always used a tubing cutter and reamed the tube and broken the outside edge, but I've never had to do any serious production work. I could afford to be finicky.
Why do most of the people who said they used tubing cutters only score it then break it?
I know pipe cutters leave a semi tapered hole and maybe a little sharp. Is that the reason?
If so, wouldn't take much effort to ream it a little after cutting.
It works great. Once you get a feel for it you can score and snap and leave a smoothe edge inside the counduit with no need to ream at all.No one ever showed me the score and break trick so I don't know how well it works.
I have an old uni-bit that I can chuck up in my cordless drill should the need to ream occur.Maybe my hands are just old and tired, but gripping the EMT hard enough so you can bear down on the reamer makes them ache something fierce after 20 or so. Holding the EMT with ChannelLocks helps, but you're still mashing the reamer in pretty good and that gets old quick.
Again being kind of old school, I didn't have insulated Channel Locks, so I would just put those in the end and ream the pipe. Then I got a barrel reamer, but didn't always have it handy.
I once heard that is was impropper to use a tubing cutter for EMT. There was an inspector in Los Angeles that who would not let you use one. He even would tell you put that thing back in the truck if he saw you running EMT and it was visible in your pouch.
I suppose not an issue by all the posts.
One of those tales.
I did not care about this idiot inspector because I had my trusty Makita battery sawzall and I could cut faster than anyone on the job. I ran circles around the guy with the bandsaw. I would laugh at the guys who would try to use the Makita as they would break the blades all the time. I knew how to use the tool with breaking the blades. I also used this cutting wax stuff on the blade that acted like lubricant and kept the blades from dulling quickly.
