logan92@att.net
- Round Rock Tx
I was wondering if I ran conduit in a straight trench how long does the run have to be before i need a pull box? I searched the 2011 NEC and couldn't find an article showing me the code
... If you were to go around the earth in a straight line you would not exceed three hundred sixty degrees which is the only restriction the NEC has when it comes to pull points.
Well if you can make around the earth then getting one end of the conduit up past the atmosphere is not so much more work.
if you go to the vacuum of space, you will have to put a seal off,
to keep the earths atmosphere from leaking out to space. so,
after you pull it, who's gonna go up into space to pour the
seal off?
then, there are expansion joints. they aren't air tight, either.
now, about the conduit supports.....
