logan92@att.net
- Round Rock Tx
I was wondering if I ran conduit in a straight trench how long does the run have to be before i need a pull box? I searched the 2011 NEC and couldn't find an article showing me the code
You either need one every hundred feet, two hundred feet or any length you want, if you have a vacume to suck a string through. The othe lengths are based on the lengths of your fish tape.
There is no rule.
There is no rule.
You need a slight extra length as it comes from the factory to allow for the length you burn off occasionally pushing it into a live panel.If it is based on the length of many fish tapes it would be more like 185 feet. Just saying! One of my pet peeves!
You need a slight extra length as it comes from the factory to allow for the length you burn off occasionally pushing it into a live panel.![]()
Now if OP is asking what is practical, he will not find that in the NEC. He could try asking members for their opinion on that question based on their experience. They will probably ask him about size of conduit, type of wire (including how much pull it can take without damage), and conduit fill factor.unlimited , you can go 800' with no junction box if you like, not a code violation
Apparently the posters have not heard of wiring pulling tension calculations.
The conduit run can be as long as you want it, provided the maximum pulling tension is not exceeded, which if exceeded will cause permanent damage to the cable.
A qualified cable installer will know how to perform those calculations.
For online calculators, try the websites of cable manufacturers like Southwire.Do you know the fomula? Where would one find the calculation method. Sounds like a POCO job
