weressl
Esteemed Member
Hi, I have a reduced voltage motor starter with the contacts submersed in oil.
I am trying to find oil to add/change, any ideas what oil might be in the starter ? transformer oil ?
Supply house said the oil is obsolete but they can get it in 4 oz containers at $60 bucks each, that will be very expensive
seeing I need 5 gallons.
This is an old Cutler Hammer starter you pull the arm forward to start the motor and when at speed push arm back to run.
Thanks for any help
Dave
That is outrageous! Depends on where you are look for a transformer repair service, they buy it in bulk for $4-8/gal and sure would be willing to sell it at some profit margin. That would also assure that you would not be ADDING PCB contaminated oil. (EPA had a deadline to have all those oil filled equipment tested and labeled for PCB content. That was a long time ago.)
If not, try this one:
http://products.lelubricants.com/item/transformer-oils/transformer-oil-6760/6760
