Here is our application:  3 phase 460V  150HP submersible pump/motor  Namplate Data: amp = 220  SF = 1.15  PF = .880  kVA code = J
Continuous Duty Squirrel cage Rotor Design ? Size 5 starter and 200A fused disconnect (200A Frame) is what is presently in place and was used on the previous motor.
Is the sizing of motor protection (DE Fuse), wiring, overloads different for a submersible? Based on Nameplate Data the FLA is higher than a standard pump motor. Generally table 430.250 is close to the nameplate amperage but this is not the case here. Any guideance would be appreciated.
Looking to do it right
