(B) Branch Circuit Extensions or Modifications ? Dwelling Units. In any of the areas specified in
210.12(A), where branch-circuit wiring is modified, replaced, or extended, the branch circuit shall be protected by one of the following:
Changed From 2008
210.12(B): Added new requirement for AFCI protection where branch circuits are extended or modified.
(1)
A listed combination-type AFCI located at the origin of the branch circuit
(2)
A listed outlet branch-circuit type AFCI located at the first receptacle outlet of the existing branch circuit
406.4(4) General Installation Requirements.
(4) Arc-Fault Circuit-Interrupter Protection. Where a receptacle outlet is supplied by a branch circuit that requires arc-fault circuit interrupter protection as specified elsewhere in this
Code, a replacement receptacle at this outlet shall be one of the following: ?
406.4(D)(4): Added new requirement covering replacement of a receptacle at a location where arc-fault circuit interruption protection of the branch circuit is required.
(1)
A listed outlet branch circuit type arc-fault circuit interrupter rece
(2)
A receptacle protected by a listed outlet branch circuit type arc-fault circuit interrupter type receptacle
(3)
A receptacle protected by a listed combination type arc-fault circuit interrupter type circuit breaker
This requirement becomes effective January 1, 2014.
