jaylectricity
- Massachusetts
- licensed journeyman electrician
I just learned about this code from the 2009 IRC. For anybody who doesn't know, if you have an exhaust hood at a certain cfm (400, usually) that exhausts to the outside you must have a way to makeup the air pressure. Apparently they're worried about the hood drawing air through the chimneys and plumbing vent pipes.
Those issues aside I'm not clear on what I'm supposed to do. We have the hood installed and we have a makeup air vent with some sort of powered damper. The thought is that it's supposed to open when somebody uses the hood. How do I make that happen?
According to a few websites there's supposed to be some low voltage terminals on the hood but I'll be darned if I can find them.
The model is electrolux rh36wc55gs, but the installation instructions don't mention it. The online instruction manual mentions it, but just says, "Local codes may require makeup air ducting."
