- Placerville, CA, USA
- Retired PV System Designer
Lenz's Law itself is vague, but very powerful as a result!Your clarification does not explain why the induction motor runs or why an inductor stores energy in its magnetic field i.e it is vague.
I was not trying to explain why the motor rotates or why torque depends on slip for an induction motor. Just to correct some misstatements which had been made by others.
Then there is no sense in stating stator magnetic field opposes the rotor magnetic field or vice versa in an induction.
If you look at the total resultant magnetic field at an area in space (for convenience we assume an area not occupied by a ferromagnetic material), then you can use the following terminology:
1. A single sum magnetic field vector can be decomposed for convenience into several components which are generated by two or more different sources. The linearity of electric and magnetic fields allows us to do this decomposition and superpostion.
2. If the field contributed by source B acts to cause the overall magnetic field to be lower than it would be if only source A is present, I say that the field of source B opposes the field from source A. Makes perfect sense and is a quite useful concept. Another way of looking at it is that the field vector from B is in the opposite direction to the vector from source A. Or at least that the component which is parallel to field vector A is opposite.
It is a convenient way to determine the direction of the induced field without spending several minutes applying the Right Hand Rule and getting confused about the direction of conventional current versus electron flow.
