senoirbubbles
- Clearwater, Florida
I have code questions. I have a job whereby somebody double tapped the lugs of the load side of a 100 amp main service disconnect to feed a 30 amp sub-panel that feeds a small window ac. I would like to redo this and make it correct. My solution to fix this without replacing meter cans,disconnects and making it a huge job is this: I would like to tap into the load side of the#4 wire using #4 with a split bolt or a polaris and run a small sub panel underneath the main disco. The sub-panel would then feed the a/c. Or, I would like to tap into the feeder from the meter to the main disconnect with split bolt or a polaris with #4 wire and feed a sub panel underneath the main disconnect. I would have to do a load calculation to make sure sure the new load added to the existing load doesnt exceed to the meter can amperage.
Please find pictures attached
