Andy Cazzato
- Aptos, CA, Santa Cruz Co.
I have a customer whose house was wired during original construction for a string inverter using Romex for DC conductors between the roof mounted modules and the inverter in the garage. The romex runs thru the attic and inside sheetrock walls. An entire of subdivision of homes is wired this way.
To my knowledge, Romex has never been allowed for DC conductors without metal conduit. This house would require considerable time and material to abandon the Romex and run conduit externally thru walls and over roofs to connect the modules to the string inverter location. The inverter is a Xantrex ST which has failed and cannot be repaired, so a replacement string inverter would also add to the cost of adding external conduit.
If we convert this system to microinverters will the Romex be allowed to carry AC (240Vac, 7.1 A max) without conduit or would new metal conduit be required regardless?
In case you're curious, these new homes were inspected and passed by the City of Watsonville, CA between 2001 and 2003 with the solar built in.
Andy Cazzato
Santa Cruz Solar
Andy Cazzato
Santa Cruz Solar
