I'm working on an estimate for a house that was converted to an apartment. There has been some work already done on it and there are 3 separate apartments. Each has there own breaker panel installed inside and has a disconnect on the outside of the building. As of now, they are all running through one meter but they want to meter them individually. They want a triple gang meter socket so each of the disconnects on the outside of the building can be fed by it's own meter. I'll try to explain this as well as possible. On the outside of the apartment there is a 100 amp disconnect that feeds a panel inside with a 100 amp main. Disconnect number two has a 200 amp breaker in it and it feeds a panel with a 150 amp main in it. Disconnect number 3 is the same as number 2 and has a 200 amp breaker as a disconnect outside and feeds a panel with a 150 amp main. So, I have a 100 feeding a 100, a 200 feeding a 150, and another 200 feeding a 150. The wire between the 200's and the 150's is sized for the 200's so that should be fine, but when sizing the service entrance should I use the size of the disconnects outside or the size of the main breakers in the panels since they are the only load on their own disconnect? Also, what can I derate the service entrance cables to in order to feed the meter socket for a multi family dwelling like this?
