You really have a lot more faith than I do. I believe this the same group that sent us equipment last year that ran 480v thru the vfd aux contacts. No, they are not rated for it.
No. My base case is always that there will be some bad thing that could happen, due to willful intent, incompetence, clueless pretend professionals faking it ... I like to see it in advance and cite it, but the effort commonly does not yield the necessary result. I document it and try to let the liability fall elsewhere.
Had this golf course irrigation controller to wire early in my time as a contractor. Town Public Works bid job, designed, spec'd, by a professional golf course irrigation engineer, professionally built custom controller, for two 10 stage 20 hp Goulds pumps. All I had to do was bring power to it. But I went through the control scenario from the wiring diagram, then I saw at zero flow, the off condition, it would pump for three minutes on a timer into a closed valve (a two port, in and out, PRV, pressure reducer, a monster the size of a fire hydrant).
I told the town they were nuts and they could not cavitate a ten stage 20 hp pump for three minutes on a timer into a closed valve. They had no clue what I was talking about but they did pay the engineer door to door travel from out of state to come to the job, watch me point to the wiring diagram and show him the problem, then he says "it will work perfectly".
I had a contract to perform on and I wired it and put it into service. I also called Goulds Pump and got the right person on the phone and asked him if his pump was rated for zero flow and full load, the on condition, for three minutes. He says "where is that job, I'm pulling the warranty off that pump".
Town calls me six months later. They had now discovered the problem, but not the problem I had thought. The PRV was pinging the 400 psi inlet pressure gauge, so they had replaced it with a 1000 psi guage to get a reading. The PRV failed at six months and they took it apart and sent it out for rebuild. They said all the metal parts at the inlet were pushed in.
