ajayl
- spring creek, NV, Elko county
I was asked to do a job wiring a new barn 60ft by 45ft. The utility service is 200Amps 120/240v single phase. The feeder (4/0 aluminum) comes from the service to the main panel 561ft away! This main panel has a feeder that supplies a double wide trailer home and a garage that is 24ft by 36ft. The new barn is 100ft away from the main panel.
If I run a 200 amp feeder (4/0 aluminum) to the barn and the maximum load of 150amps this would have a 12% voltage drop!
What I am asking is do you think a 200 amp service is big enough for the house, garage and barn?
There is another option, I could get a service on the other side of the property that would be 150 ft from the barn and 200ft from the house. If I did this it would solve the voltage drop and I could get a 400 amp service. Is 400 amp service to big?
What would you guys do on a job like this would you settle for a 12% voltage drop and a feeder so far away?
Sorry if this is a confusing explanation I will try to clarify if needed. Thanks for any help.
