cobrahead
- Fort Worth
520.25 Dimmers
(D) Solid-State-Type Dimmers. The circuit supplying a
solid-state dimmer shall not exceed 150 volts between conductors
unless the dimmer is listed specifically for higher
voltage operation. Where a grounded conductor supplies a
dimmer, it shall be common to the input and output circuits.
Dimmer chassis shall be connected to the equipment grounding
conductor.
I got a test question about this. Does it mean the grounded conductor should be considered a current carrying conductor?
conductor.
