steve holt
- Hawaii
Can a legally required emergency generator be located in a room in which the only access in or out is through a roll up gate? The gate is 2 hour rated, and will automatically drop if the fusible link melts. If the door drops, the only way out (or in) is to manually lift the door (I am assuming from the inside). The OCP is only 1000A so it doesn't fall under the over 1200A rule, but it doesn't seem like a reasonable arrangement.
