JoeStillman
- West Chester, PA
- Electrical PE
More importantly you, like me, did not read the OP's question carefully enough.
He asked whether lowering the PF seen by POCO would decrease his bill. And the answer to that is a resounding NO. It would actually increase his bill slightly for the reasons we discussed. And if he were a commercial user it would increase it a lot because POCO does not like supplying power to low PF loads.
lakee911: There is nothing good about low power factor. It has only neutral or bad consequences, depending on what part of the whole power distribution you look at and to what level of detail. The combination of low and power in sequence gives many people the wrong impression of what it means. Low Power Factor has nothing to do with Low Power.
/me eats more humble pie, repeats to self; 'low power factor =bad, high power factor = good, lather, rinse repeat..."
Low power factor = high reactive load. Reducing reactive load is what I should have said.
