Nycedreemz
- North Carolina
I was speaking to a friend of mine who was in need of a locking generator cord. Well being the nice guy that i am i offered to assemble him the L14-30 cord he needed. When i got his cord assembled and brought it home from work to give to him, he looked at it and asked about the 125v/250v rating stamp on the plug and connector end. I explained to him how the four prong L14 series plugs, connectors ect. are able to be wired with a 125v or 250v output. I didnt think much of it then but now i have this burning in my brain. I have never seen this before and have spent quite some time searching. I would like to get a few opinions on this if possible. Lets just say you have a three way three conductor splitter cord, the plug end will be an L14-30P and the two connector ends would be one L5-30R connector and one L6-30R connector. Utilizing both of the L14-30P's voltage capabilitys within one cord assembly. I have assembled this myself by terminating 2 hots and a ground into the L14-30P for the L6-30R, double tapped the one hot, tapped the unused nuetral, and shared the ground into the same L14-30P for the L5-30R connector and tested the output at each connector with them testing correctly. My meter shows 125ish volts 30A at the L5-30R and 250ish volts 30A at the L6-30R. This however has not been tested with both connectors under a load. Only one at a time. Now im am completly aware that a typical residential service is 250v. Im just curious if anybody has ever seen or heard of this kind of splitter cord setup ever. I like the idea of having the ability to utilize either of the voltages possible. My concerns are what may happen if both are placed under load at the same time. Good Idea:thumbsup:? Bad Idea:thumbsdown:? Thanks in advance for anybody input or thoughts.
