francis.key19
 - frederick, md
Hi,
We have a small machine maintenance shop in our facility. The shop has several table saws, grinder, drill presses. All of these machines came with plug in cords from the factory. They are all 120VAC and one is 208VAC.
Some of these machines were bolted down to improve stability and some are ok free standing. We were told by our superior that if the equipment is bolted down, it is considered a permanent installation and thus the machine will have to be hardwired instead of using the factory provided cord. If we don't want to do this then we have to not bolt down the machine.
This sounds unreasonable to me. He says that NEC code require hard wiring for permanent installation. My question is what article in the NEC required power tools to be hardwired. If a machine was made with a cord and pass all the UL, CSA..etc.. sold commercially for use by plug into a receptacle, taking it apart to hardwire it does not make sense.
For example, our 70" monitor is mounted permanently in the conference room, but we do not have to disassemble it to hardwire it via conduit to a CB.
Thank you.
Francis.
Thank you.
Francis.
