dnbob
- Rochester, MN
Is there a requirement to protect field cut threads in rigid aluminum conduit?
I can't find any requirement.
Put No-Ox on them so they will form a good bond when used as EGC?Protect from what?
Are you actually talking about Noalox (NoAluminumOxide)? That is not intended as an anti-seize lubricant although it may serve that purpose.Even though there isn't a requirement for any protectant on the threads, I always use NoLox on all aluminum rigid conduits.
It helps with lube in the couplings. Aluminum likes to cross thread and gaul very easily, and the NoLox lubes the threads very well. Using it is we'll worth it.
or balm for chapped lips; cracked hands, or deodorant when you need to go to a dinner right after work.Based on reports I have seen from practicing sparkies, nothing beats Noalox when you actually need an anti-oxidant.
