Pretty sure i know the answer, but is there any way i could use a SMA TL inverter on an existing system built in 2002?
(The (E) SMA 2500U needs replacement.)
(USE wire, not PV wire used)
Why does Code require PV wire for ungrounded systems and not GFDI fuse protected ones (grounded)?
The way i see it: this inverter has AFCI, gr. fault detection and is the latest. Why the extra requirements in DC conductor insulation?
Code aside, wouldn't it arguably be better than using a grounded, previous model? (e.g. SMA SB4000US)
