powerplay
- In front of a computer.
Customers prefer to mount tv's over fireplaces it seems.... Is the heat from the fireplace going to damage the tv?
Honestly, if someone is so unaware of proper viewing to want a TV over the fireplace, then who cares if it's damaged from heat. They probably don't use the fireplace much anyway.
Anybody with half a brain will quickly figure out that their neck strain is caused by the TV being mounted to high.
TV 101 - The center of the screen should be at eye level while you are sitting.
If you are reclining on the couch, the TV may well be in your line of sight without neck strain.Honestly, if someone is so unaware of proper viewing to want a TV over the fireplace, then who cares if it's damaged from heat. They probably don't use the fireplace much anyway.
Not only that, but when the kids (or grandkids) stand right in front of the TV, there's no longer a need to yell at them to sit down or move. Now they can stand there or run back and forth all they want, and you still have an unobstructed view of the screen above their heads. That's been the single greatest thing about my dad deciding to mount his 60" above the fireplace.If you are reclining on the couch, the TV may well be in your line of sight without neck strain.
I agree that it depends on the fireplace whether heat will be a problem. I tried to edit my earlier post to say this, but I guess I waited too long and the option to edit had already disappeared.Places for tv over fireplace:
Mancave
Country Club
Locker Room at the gym
etc...
I can see it being designed that way by some artsy interior designer with no common sense.
It's a matter of whether that fireplace produces heat. Many are only aesthetic and have no heat at all.
I wouldn't put one over a wood burning fireplace, but a tiny gas log that barely toasts a marshmallow? No problem!
I am such a noob, I was under the mistaken belief that the correct location for a TV is where the TVs owner likes it.
As far as the heat above a fireplace, don't we often find, pictures, flowers, portraits, plastic nicknacks etc. above fireplaces?
And a gun over the fireplace in the first act will be used by someone by the end of the third act.And guns .
