I'll try and keep this simple
(4) 4" rigid conduit entering a pull box on one side and (4) 4" leaving from the opposite side.
Conductor/amps not necessary for this question.
All 4" knock outs made via knock out punch, not pre-made.
Hence it's my understanding that ground bushings are only required at the ends, not at each pull box if no
splices occur in the pull box.
What I've see in the field is (plastic bushings only) on the pull box entry and exit.
With ground bushings at either end of the run.
Now let's say the engineer has required ground bushings on every conduit at every pull box.
The conduits in question have an appropriate ground wire run inside along with phases and neutral.
What I've seen in the field more than once is a much smaller ground wire, than is contained in the conduit
run, bonding all the ground bushing together and finally to a lug on the metal box. No connection with the feeder
ground wire.
Where the conduit is grounded without the bonding jumper, is this procedure legal?
Thanks, hope it's simple enough.
ground wire.
