hopemoon
- Bogota, Colombia
Hi,
I want to know if there is a numeral into the Electrical Code that allows motor supplies with a different voltage that the nominal? For example, can a 460V specified motor be run on a 480V mains supply or the other way round?
How does it affects my cable? I mean, I should calculate the cable with the voltage supply (480 V) or with the nominal voltage (460V)?
Which is the current value that I have to use to the MCC load summary? The nameplate power affected on 480 V or?
Thanks in advance!
Thanks in advance!
