captainwireman
- USA, mostly.
As I interpret the code,
A. I could run say 50 feet of type MC cable, 12/2, on joists spaced 18 inches apart for 50 feet and never have to put one staple or other approved method (exceptions not included) as long as I secured this cable within the code from both junction boxes on either end of this run and be code compliant.
B. I could use a typical tie wrap (cable tie) with an eye that a wood screw drilled into a wood framing member as an approved securing method within 12 inches of a sub-panel.
C. If two lighting fixtures wired in with MC cable are within 23 inches of the connectors to these fixtures mounted on the steel cross arms of a commercial shelf, typical in big box stores, this MC cable is considered supported because the connectors are considered a means of support for this cable.
Once again, I am at war with those that huff and puff but can not show me the specific code section.
