swflelectric
- South West Florida
We have a company looking to install a above ground (under 500 gallons), double wall 120v driven gas tank(motor mounted above tank) for there Rental car business. We have a sub panel(6 space 60amp Single Phase) at that end of the parking lot that is around 50ft away from the container (container and panel located outside). Out of that panel there is only 2 GFCI outlets general purpose. We have a neutral kill 20amp 120v kill breaker installed for feeding the 120v pump and installed explosion proof fittings, and seal offs through out. We had a meeting with our inspector today and told us to install a mushroom style disconnect switch and make that entire panel shunt proof. The problem is how do we make this sub panel into a 60 amp main breaker shunt proof panel. I understand what he is saying but to even add the shunt at the main building it is over 400 ft away. Any ideas how we can comply with code and make this safe? Are there any products made specifically for this type of installation?
