Ravenvalor
- Triad region of NC
- Electrician
Hello,
Today I came across a new stand-alone GE double oven with range that was rated 14,400 VA, 240-volts and the installation manual recommended either a 40-amp or a 50-amp circuit for the range. I called the manufacturer and the rep said to follow the installation manual's instructions. I called the electrical inspector and he said the same thing, put it on a 50-amp circuit. I installed the range and measured the amperage and it was over 50-amps. Now I have a customer who is afraid of using too many items on the range at one time. That was the first time I had ever encountered a contradictory instruction from a manufacturer. I am sure there is a good explanation but I can only assume that GE has enough lawyers to get away with this and they can't resist the temptation to sell a stand-alone double oven with range that will operate on a standard range circuit.
Corporism, you gotta love it.
