Steam Generator
Toros
Tujunga, CA
Hi,
can I install a steam generator of master bath in the attic space of that bed room?
Will it generate uncompfort, noise.......????
Thank you
Usually the plumber installs them and the electrician runs the power to wherever the unit sits.
Never seen one in an attic here because it gets cold in the winter.
Yea, good thinking!! Frozen pipes can cause some discomfort!! And a lot of noise when the owner sees water everywhere!!
This could sound cliche but you might have to check with the AHJ.
This is because there is tanked water(in what ever state); this is might well require a belly
pan and a float indicator.
The HVAC SH sells isolation squares and pads.
Know any plumbers? :)
