- NE Nebraska
- EC
Here's what I found: there was a timer on the wall of the laundry closet (stack washer/dryer, 230v) that controlled the dryer outlet and a dryer vent booster fan. Customer just didn't know the timer was there. I'm guessing the booster fan is used for more then one unit, and management doesn't want it running unless it's needed, hence the timer/relay interlock.
See or learn something new all the time.
Would seem to me that either a current sensing relay or an air pressure switch would be a better way to control the booster fan, otherwise the setup you are describing limits when the dryer can be run, and runs the booster fan even if the dryer is not running.
