I just ran across a wiring scheme for a GFCI I have not seen, nor done myself before.
The Line & Load Neutrals on a GFCI have their pigtails tied together with the Neutral from the breaker panel inside the box for the GFCI.
Intuitively, this is yelling out "Wrong!" to me. Yet the GFCI appears to be working OK & trips when the Test button is depressed. Yet, I do not trust this wiring scheme at all. Essentially this seems to me to equal the same thing as if one wired both the Line & the Load Neutrals each to both the Line & Load terminals.
This wiring scheme does not seem to me to be an acceptable practice (Tying the pigtails from the Line & Load Neutrals on a GFCI together with the Neutral from the breaker panel) even if the GFCI appears to still function.
Am I correct that this is an unacceptable wiring practice for a GFCI?
I have never seen any wiring diagram anywhere for a GFCI that depicts this particular wiring scheme.
