maintenance man
- paoli, pa
A underground feed in pvc 4 wire 480v is going out to another building to a mcc. From that mcc it is feeding a panel listed as 480/ 277 .
Is the fourth wire a neutral or egc ? When it leaves the mcc in gal pipe to a 480/277 panel there is no change over from a transformer 480-480/277 to get a neutral. The fourth wire goes to the neutral bar should it be bonded to the panel ? What is wrong here? I do not find any gec connection anywhere.
This is a older design I have not seen before just trying to understand how it was done then.
Thanks to all or anyone for their help with this design.
